Video Capture trough Firewire A/V DV Capturing Device
  • trukske
    by trukske » Tue Sep 19, 2006 9:20 pm
    I am unable to capture video from a cctv security camera through a PYRO AV-Link A/V capturing device, that is connected with the computer via firewire. The resolution of the camera is 510x492 (PAL).
    Can anyone tell me if it is possible to use an external A/V video capturing device with firewire output, in stead of a camera? We work a lot with cctv cameras for theatre, and they only have a cinch output.
    Thank you,
    Ief.
  • freespirit
    by freespirit » Tue Sep 19, 2006 11:05 pm
    I use a Canopus ADVC-100 without any problems in Modul8 for external video capture. If I get my laptop back from repair I can try it with te Beta if it still works but it used to work.
  • trukske
    by trukske » Sat Sep 23, 2006 6:02 pm
    with camera are you using? Maybe it is beceause of the resolution of my camera? A small security cam.
    thanx.
    ief
  • jm302
    by jm302 » Sat Sep 23, 2006 7:42 pm
    trukske wrote:Maybe it is beceause of the resolution of my camera?
    That shouldn't make a difference. Does it work with any other app, like Quicktime? If not, try plugging a DVD player into your firewire A/D box and see if you get an image. If it works, then you have a problem with the camera, if it doesn't, it's the A/D box (or the drivers for it). Good luck!
    Cheers,
    Justin
    P.S. I just plugged my PV-GS300 into the beta7 and it works fine.
    http://www.302acid.com
  • trukske
    by trukske » Wed Oct 11, 2006 2:00 pm
    Hey, i tried it with a dvd and that worked... So i tried again with the camera but that didn't work. Now i'm using another small security cam and that is no problem. So it was the camera... He's not broke beceause i tested it connecting him directly on a tv screen and that was noproblem. So i don't know what was the poblem.. Anyhow, i can capture video now. Thx for your help!
    (nice video on your website°!)
    greetz
Users browsing this forum: No registered users and 61 guests
