Invert values?
  • Akira
    Invert values?
    by Akira » Wed Sep 27, 2006 9:30 pm
    Hey module freaks ;)
    I want to do a module that takes input from a MIDI signal and outputs it in inverse fashion to a modul8 parameter.
    I mean, if I go from 0 to 127 in my knob, it has to send 127 to 0 to the parameter (reverse order)
    I guess it can be done through the interface, and not straight with the MIDI values!
    what's the algorithm to invert the values like this? I would like NOT to do a huuuuuuuuuuuuuuuuuuge comparison table :?
    Cheers!
  • Lupin
    by Lupin » Thu Sep 28, 2006 4:39 pm
    i consider your input value as a variable named valueIn
    here is the algorythm you can use
    Code: Select all
    newValue = abs(127 - valueIn)
    that simple :)
    enjoy
  • Akira
    by Akira » Thu Sep 28, 2006 9:33 pm
    I can tell it's been 8 years since i went out of computer science studies :P
    cheers lupin!!!!!!
    by boris » Fri Sep 29, 2006 12:17 am
    Still more simple...
    Code: Select all
    value = 127-value
Users browsing this forum: Google [Bot] and 32 guests
