position grid
  • collett
    position grid
    by collett » Wed Oct 04, 2006 10:08 pm
    is there any way you can manually input the position of a layer.
    dialog box would be handy, so you can enter x and y or some way to copy position of one layer too another.
    :D
  • Lupin
    Re: position grid
    by Lupin » Wed Oct 04, 2006 11:01 pm
    collett wrote:is there any way you can manually input the position of a layer.
    :D
    if the grid window isn't enough accurate for positioning yoru layers, the solution is to write a module where with number fields and push btons to select layer number for instance.
    if you don't feel like writing this module i'm sure many Modul8 coders will help , you can even ask me if you want
  • collett
    by collett » Sun Oct 08, 2006 1:22 am
    hey lupin
    thanks for the response, sadly im worse than useless when it comes to programming, any help would be fantastic.
    cheers
    matt
