Layer select from the MIDI controller
  • mojopikon
    by mojopikon » Mon Oct 09, 2006 4:32 pm
    I own a BCR2000 midi controller, and I want to ask if there is any way of using the top keys of the controller for selecting the active layer. I can assign the keys to the clips ,but I'm not able to assign them to the layers.
    Does anybody know how to do this?
    Thanks :-), and sorry for my poor english.
  • defect
    by defect » Mon Oct 23, 2006 11:18 am
    Hola,
    don´t work...i need that feature too....i think there is a module for that but i don´t try it...
    greetz...
  • jm302
    by jm302 » Fri Nov 10, 2006 6:16 am
    I'm pretty sure you can map those buttons to the layers (my bandmate did this a bit back)... make sure you're in "Focus" mode in the MIDI mapping.
    Cheers,
    Justin
    http://www.302acid.com
  • mojopikon
    Using midi events for selecting active layer
    by mojopikon » Fri Nov 10, 2006 11:36 am
    As you can see in the screenshot, that is not possible :-(
    I would like to be able to switch betwen those layers without using the mouse/touchpad, just using my midi controller :-)
    ^_^
  • vjjv
    by vjjv » Fri Nov 10, 2006 10:38 pm
    That's a screenshot from the focus midi...
    try it from the position tab at the top.
    Good Luck..
    BTW I have a bcr-2000 and it works..
    "Know your monkey"
  • jm302
    by jm302 » Sat Nov 11, 2006 5:44 pm
    Yeah, sorry, VJJV is right, you should use the Position tab. Here's a MIDI template we used from our last round of shows:
    Hope that helps.
    Cheers,
    Justin
  • insane insan
    by insane insan » Wed Nov 15, 2006 2:03 pm
    Hi there,
    I know maybe im not in the subject with you guys bit i see some midi triggering there and i have the same midi controller, bcr2000 and a trigger finger can somebody please send me a middi map ready triggerd for any of these controllers...
    Sorry if my question is stupid.
  • mojopikon
    by mojopikon » Sat Nov 18, 2006 3:38 pm
    Your answers were really helpful.
    Thanks a lot ^_^
