Modul8 choking on clips in compressed memory
  • deckard97
    by deckard97 » Tue Oct 10, 2006 7:48 pm
    I have an issue with Module8, I have a video clip, 720X480 on a 1024X768 stage, medium photoJPEG compression, 30fps, around 7 minutes in length.
    Got a G5 dual 2GHZ, 2.5GB of RAM, geforce 6600, RAID 0.
    I import it and have it load in compressed memory (640MB), so basically it's totally stored in the RAM.
    I then control the playback of this clip through MIDI, I play it once, rewind a bit, increase speed, then normal speed, etc, for about 10 minutes (it's for a theater play).
    But then after a while, Modul8 starts to choke, when I fast forward through the clip (increase the layer's speed), Modul8 increasingly chokes up to the point where I get 1 frame per 10 seconds and then it totally hangs.
    Activity Monitor reports Modul8 only uses about 1GB of RAM, so there's plenty left, and it's not even using all of the processor's cycles and I have no other application running.
    I had to quit and start over for Modul8 to start behaving normally.
    It seems like the more I play with a movie clip, the more it chokes up on it, which is odd for me since the computer's performance is not taxed and there's plenty of power left.
    Let me know if you need more info or even if you want me to post this in the french section of the forum.
    Thanks
    Re: Modul8 choking on clips in compressed memory
    by boris » Thu Oct 12, 2006 1:06 pm
    What version of modul8 did you use, what version of macosx, quicktime...
    Do you have only one geforce 6600 or more ?
    Can you check the free physical memory on your computer when the problem come ?
    Thanks.
  • deckard97
    by deckard97 » Thu Oct 12, 2006 7:31 pm
    One GeForce 6600.
    QuickTime 7.1.3
    OS X 10.4.8
    Ok, just tested it again, here goes
    System Memory:
    Wired: 210MB
    Active: 150MB
    Inactive: 1.87GB
    Used: 2.21GB
    Free: 300MB
    VM Size: 8.26GB
    by boris » Thu Oct 12, 2006 8:42 pm
    Can you open a terminal, write "top" ->enter
    And copy all data...
    And also what is the version of MODUL8 did you use ?
    Thanks.
  • deckard97
    by deckard97 » Thu Oct 12, 2006 11:06 pm
    Modul8 Version 2.03.
    here's an average of TOP:
    Processes: 51 total, 4 running, 47 sleeping... 186 threads 17:01:44
    Load Avg: 1.49, 0.81, 0.38 CPU usage: 59.5% user, 6.3% sys, 34.2% idle
    SharedLibs: num = 172, resident = 39.3M code, 4.27M data, 5.95M LinkEdit
    MemRegions: num = 6877, resident = 1.09G + 8.63M private, 98.4M shared
    PhysMem: 216M wired, 140M active, 1.88G inactive, 2.22G used, 281M free
    VM: 7.95G + 123M 29079(0) pageins, 120(0) pageouts
    PID COMMAND %CPU TIME #TH #PRTS #MREGS RPRVT RSHRD RSIZE VSIZE
    649 top 7.7% 0:04.10 1 18 22 460K 296K 2.29M 26.9M
    641 bash 0.0% 0:00.01 1 14 16 156K 744K 812K 27.2M
    639 login 0.0% 0:00.01 1 16 36 148K 312K 572K 26.9M
    637 Terminal 0.3% 0:00.53 4 91 123 1.75M 8.02M 6.43M 357M
    635 MIDIServer 0.0% 0:00.54 15 284 166 2.35M 5.46M 6.71M 306M
    634 Modul8 115.1% 4:29.46 14 198 817 1.01G- 38.9M 1.01G- 1.42G-
    615 mdimport 0.0% 0:00.52 4 62 54 1.05M 2.80M 3.16M 39.8M
    571 cupsd 0.0% 0:00.54 2 30 26 672K 776K 1.64M 27.9M
    379 StuffItCM 0.1% 0:28.73 2 81 226 3.20M 13.3M 20.0M 384M
    256 AppleSpell 0.0% 0:00.51 1 32 34 764K 1.57M 1.93M 37.4M
    224 check_afp 0.0% 0:00.00 2 26 22 216K 564K 776K 27.1M
    208 nmbd 0.0% 0:02.64 1 14 24 268K 812K 1.10M 27.8M
    206 slpd 0.0% 0:00.42 6 31 33 252K 692K 984K 30.2M
    199 mds 0.0% 0:08.67 8 96 96 4.00M 1.67M 4.79M 44.6M
    191 AppleFileS 0.0% 0:01.14 2 40 43 2.93M 1.09M 3.21M 34.0M
    177 Mbox2CS 0.0% 0:00.05 2 27 27 304K 576K 1.04M 27.7M
  • deckard97
    by deckard97 » Thu Oct 26, 2006 4:49 am
    Hi Boris,
    do you need further information? I'd like to get some follow up on this problem.
    Thanks
    by boris » Tue Oct 31, 2006 3:23 pm
    Sorry,
    Hum your problem seems very strange, we can continue our discution in french on the support ?
    support [AT] garagecube.com
    yves@garagecube
    by yves@garagecube » Mon Nov 06, 2006 10:39 pm
    Please could you try Modul8 2.5 beta 8 and let me know if it helps. This version has a new mechanism to prevent movies to be paged out by virtual memory.
    Yves.
  • deckard97
    Fixed
    by deckard97 » Thu Feb 08, 2007 6:19 pm
    With V2.5 this issue appears to be fixed.
    Thanks
