NEW USER Question for set up .
  • timothy_boreale
    by timothy_boreale » Sun Oct 22, 2006 2:06 am
    hello everyone , i had my modul8 3 days ago .
    i just want to know how is works with my 2 computer .
    i am run modul8 in my macbook pro ,and i run motion dive . in my other pc lap .
    so could i send the pc image to modul8 , and mix it ?
    if it is work , hoe could i set up my computer ?
    otherwise , must i buy a v4 , right /?
  • JJHP3
    by JJHP3 » Mon Oct 23, 2006 12:31 am
    Yes, you can bring the PC's video into M8 and mix it with your M8 clips. First you must turn the component video output of the PC into DV using something like a Canopus box. Then make one track video-in (say in the 'A' section) and place clips in the 'B' section and it should work use the fader to go between. I've been doing very thing for the past three days.
    Hope that helps,
    John
