DVI to RGB
  • mosmedia
    DVI to RGB
    by mosmedia » Tue Oct 31, 2006 12:30 am
    Hello All,
    Does anyone know the best solution of converting DVI to RGB, RGBS, or RGBHV? I would be going from a mac pro with dual video cards to an extron video swither that takes in RGB. I have looked at this cable but did not know if it was compatible with the mac pro video card.
    http://www.computercablestore.com/detail.aspx?ID=7609
    If anyone has done this type of conversion from any dvi card I would be interested in your solution.
    Thanks
    Marc
  • mosmedia
    by mosmedia » Tue Nov 07, 2006 7:09 pm
    Hello all,
    I have confirmed that this product works well with my macbook pro. I hooked it up to our Extron video switcher that takes rgbhv signals and then out to another monitor. I am going to order the rgb only version to see if that works also. Great option for converting dvi to a video signal.
    Marc
