L-SYNCHRO & M-RESET MASTER COLOR PROPERTIES
  • Lupin
    by Lupin » Tue Oct 31, 2006 1:35 pm
    Hi Guys,
    i added 2 new modules on the Modul8 2.5 library:
    M-RESET MASTER COLOR PROPERTIES:
    I built this module cuz when i play withthe M-BPM ROUTER on invert or add properties and i stopped it sometimes it didn't go back to the original invert/add values so here's a module to reset black background, invert output colors and add ouput colors.
    L-SYNCHRO:
    This module synchronizes movie positions on multiple layers. you probably notices that when you duplicate a layer sometimes layers are are not synchro. with this mofdule you can choose the synchro pos before you trigger it and if you check the direct button you can even scratch on multiple layers
