FLASH files not working (media not supported)
  • cutup
    by cutup » Fri Nov 03, 2006 3:26 am
    I installed modul8 (fantastic app) some time ago, after the fresh install everything worked fine and I could load (and play) flash files. Now, for some unknown reason the same files won't load on Modul8 (media not supported), though they play perfectly using Quicktime. I guess an update screwed up something. I've tried everything already: installing and reinstalling Quicktime, Modul8, Flash Player, fixing permissions, etc... nothing helped. There must be a glitch somewhere though I have no idea where & how to fix it. Some user(s) experiencing the same annoying problem? Thanx in advance.
    (just for the record: the files are flash 5, uncompressed... and with the right extension)
  • lezef
    flash media not supported
    by lezef » Wed Nov 08, 2006 12:39 am
    I have the same problem. I unfortunately installedt he latest MAC OSX update, and since then all my flash (that were also flash 5) are not supported anymore. Did you do this system update?
    Sorry not to give you a solution! :(
    yves@garagecube
    Re: flash media not supported
    by yves@garagecube » Thu Nov 09, 2006 12:10 pm
    lezef wrote:I have the same problem. I unfortunately installedt he latest MAC OSX update, and since then all my flash (that were also flash 5) are not supported anymore. Did you do this system update?
    Yes it seems that it is related to a system update. We are trying to figure out what's going out here...
    Yves.
    yves@garagecube
    by yves@garagecube » Thu Nov 09, 2006 2:40 pm
    Apple decided to turn off by default Flash support in Quicktime since the V7.1.3.
    However you can turn it on in the system preferences:
    Go to the Quicktime section, and under the advanced tab, select "Enable Flash".
    We plan to stop using QT to play back Flash in future version of Modul8. This will solve this issue and improve the performances.
    Yves.
    VooZ2
    by VooZ2 » Wed Dec 20, 2006 10:22 am
    yves@garagecube wrote:Apple decided to turn off by default Flash support in Quicktime since the V7.1.3.
    Yves.
    seems it doesn't help :(
    ...[ www.myspace.com/vooz2 ]..
    .........[ www.hardtechno.lt ].......
    .......[ www.schranz.lt/blog ].......
