I asked this before, but can't find the answer I know there is a module I can use so if i create a new layer and wants to load a clip the media browser stays on the page where I am, instead of jumping to page 1.
Hi - From your description I think the module you want is the "Preset Default (layer)" module -
the option you need to check is "Use Last Mediaset Selected"
