reversing direction of still images
  • phoenix
    by phoenix » Fri Dec 15, 2006 8:35 pm
    Hi, is there something like a -y function that would rotate the image in an opposite direction?
    Thanks, Phoenix
    by sigmasix » Sat Dec 16, 2006 1:35 am
    you mean with auto rotate?
    there's a button with an arrow to the right, click on it ;)
  • Akira
    Re: reversing direction of still images
    by Akira » Mon Dec 18, 2006 6:42 pm
    Thanks, Phoenix
    Just use the rotator wheel for Y axis so the image flips.
  • phoenix
    by phoenix » Mon Dec 18, 2006 11:28 pm
    thanks, but the dial doesn't do it.
    Try it. Just put in some text. I'm wanting to achieve the affect of two lines twirling in opposite directions around the same center axis point.
    Thanks again, Puddle
    cal6n
    by cal6n » Tue Dec 19, 2006 1:17 am
    Sorry. I'm not sure I understand what you're getting at.
    Do you mean something like this:
    or maybe something like this:
    because they were just done with auto-rotate.
  • phoenix
    by phoenix » Tue Dec 19, 2006 3:02 am
    Thanks, didn't *see* those little freakin arrows to the right of xyz in auto rotate.
    Now to get it not to be upside or backwards.
    Thanks
    Phoenix
