Need a non-crashing "endless" loop
  • cerbellum
    by cerbellum » Fri Dec 15, 2006 11:14 pm
    *UPDATE: first problems solved - work work!
    Hi all,
    Now that 2.5 is final (great job!), I'm off to start working on my modules again.
    The module I'm currently working on reads a string out of a text file, the problem is that the string in the text file changes continuously (externally generated X-Y-Z coords) and I want to read the file continuously too or let's say at a given framerate (24fps) so I can use the externally generated coords in realtime (fe. using the coords to rotate a modul8 generated cube)
    I've been trying to do it with while/for loops but as there's no end to the loop, modul8 crashes. It's probably something with a periodical event but I have no idea how to do it.
    I'm using:
    Code: Select all
    //init file = open('textfile.txt', 'r') //opening the file txt = file.readline() //reading the first and only line txt = txt.split(';') //splitting the string as the coords are divided by ';' print txt //console print for checkup k = 'testvar' // I tried things like while k == 'testvar': //which it always is, so it'll continuously do the following file.close() file = open('textfile.txt', 'r') //opening the file txt = file.readline() //reading the first and only line txt = txt.split(';') //splitting the string as the coords are divided by ';' print txt //console print for checkup //but quite logically it crashes
    Help seriously appreciated and thanks in advance
    Thanks,
    Kevin
  • cerbellum
    by cerbellum » Sat Dec 16, 2006 12:08 am
    Ok so I found it out myself
    Code: Select all
    count += elapsed if count >= 0.04 : #update each second count = 0.0 file.close() file = open('textfile.txt', 'r') txt = file.readline() txt = txt.split(';') x = txt[0] x = int(x) module.setValue ('accX',0,x) y = txt[1] y = int(y) module.setValue ('accY',0,y) z = txt[2] z = int(z) module.setValue ('accZ',0,z)
    I'll keep you posted on the purpose of this thing!
