multi-projection s-video out
  • Siggi
    by Siggi » Fri Dec 15, 2006 11:52 pm
    first of all i have to say that the 2.5 version was a really great step. thank you garagecube for this i really appreciate it!
    for a project i want to use the multi-projection with 3-7 screens and one preview out. i have to use a videomixer witch means i have to convert the dvi signal to a composite or an s-video signal. i could find out that the nvida 7300gt witch comes with an macpro are not able (even with an dvi to video) adaptor to provide a video signal. the ati card are able to provide a pal signal but it's only 1 card possible to install...is there another way ecept to use an expensive vga to video convertor?
    would be great to get any information.
  • bratch
    by bratch » Sat Dec 16, 2006 12:24 pm
    maybe you should try to mix everything with a data mixer which can accept both video and data , such as that by example : http://www.kramerfrance.com/indexes/ite ... ame=vp-727
    So you don't have to downconvert your signal and always keep a data signal for your beamer. 8 universal inputs, 1 preview and a program.
    VJ-A2D
    by VJ-A2D » Thu Jan 18, 2007 2:15 am
    "is there another way ecept to use an expensive vga to video convertor? "
    That kramer rack is worth several macpros !!! not so easy to setup, if rented. And has only one pgm output... so no real multiprojection.
    Use a vga box on each output ! 80 $/€ for a "working" one.
    Of course, all that depends on what your performance is, so you might want to throw in some details, if you want people to give some useful advice !
    How many screens do you have ?
    Do you need a different image on each screen ? (in which case you don't need several graphics cards, but a 1x8 VGA distributor)
    What sort of mixer are you planning to use ?
    Do you NEED to mix analog video ?
    Plus2 Collectiv
  • jason5d
    by jason5d » Fri Aug 17, 2007 8:07 pm
    or you could go for the cheap option like i did
    buy a used dual or quad core g5 and some 256 nvidia cards
    and leave my mac pro at home
  • RickRobiN
    by RickRobiN » Thu Aug 30, 2007 7:25 pm
    second that
    Just bought 3 nvidea 6600 cards for 150 euro on ebay;)
