Midi Clock problem w. BPM (Global)
    by The Midi Thief » Sat Dec 16, 2006 8:24 pm
    I'm getting a bad midi clock read with BPM (Global). A BPM of 126 reads 6839 in the BPM (Global) module. X-Ray's M-BPM-MIDI reads corectly, however. Is this a bug or are different MIDI devices using different MIDI clock defaults? (I'm using the BPM analyzer RED Microsync Beat Xtractor).
    Regards,
    Fry up
  • momo3010
    by momo3010 » Thu Dec 21, 2006 10:24 am
    did not have any problems with midi clock, for me it works perfect. I`m using a yamaha external hardware sequencer.
    transoptic
    by transoptic » Sat Dec 30, 2006 8:08 pm
    I had the same problem reading a Midi BPM with that module.... I was trying to read a Midi clock from a freeware program called MidiClock...
    Now I use the Module "M-BPM-Midi" to receive the Midi clock and it works fine.
    by boris » Sat Dec 30, 2006 9:06 pm
    Seems strange, I had using MidiClock for the development of this module.
    Witch version of modul8 do you use ?
    transoptic
    by transoptic » Sat Dec 30, 2006 9:31 pm
    Hi!
    I'm using the final release 2.5. The BPM (global) picks up about 3900 from MidiClock, which is set at 130.
    I'm on a G5, dual 2.0. Os 10.4.8. I tried starting MidiClock first, then M8.
    I just checked it out on my MacBook, and it works fine though :)
    I can just as well set BPM manually... was just checking MIDI out...
    by boris » Wed Jan 03, 2007 4:22 pm
    I made this module from my intel macBook and you'r right the module have some trouble on a G5 computer with thw midi clock (I didn't test it on a G4).
    It seems to have a problem with the midi time stamp on modul8, we will fix it for the next version.
    Sorry for the inconvenience.
  • Hugobox
    by Hugobox » Wed Oct 10, 2007 11:32 pm
    I have a similar problem. I'm using version 2.5.4 on a mac mini. If I use the midi clock from either Live or MidiClock, Modul8 syncs to the actual bpm times 3, so a bpm of 100 in Live results in a BPM of 300 in Modul8.
    by boris » Thu Oct 11, 2007 3:08 pm
    Your mac mini is intel or g4 ?
