advanced output - scaling output windows on desktop
  • k
    by k » Mon Dec 18, 2006 1:13 am
    i'm preparing an output setup for display on a led-wall. actually, the led-wall consists of three panels - two small ones on left and right side, and one large in the centre of the stage.
    thanks to your great (GREAT! ; ) "advanced output setup" options, it's no problem to arrange three clips with corresponding dimensions and positions.
    but here comes the real problem: the led-wall receives its video signal from a dvi output. no problem so far. i can arrange the three output clips on my "second monitor", what is the dvi out, which is connected to the led-wall. but i can not scale down my two smaller clips (128x288px each) to that size! it seems that the minimum width for "output screens" on the desktop is 320px.
    i understand that it's useful to define a minimum width and -height for them, but it should always be possible to display output clips at their real size.
    thanks a lot in advance for help!
  • k
    problem solved - with modul8 v2.6.1
    by k » Sat Apr 03, 2010 2:49 pm
    so, i'll answer my own question: the mentioned problem doesn't exist anymore, in modul8 2.6.1.
    confusing: if you define a clip in advanced output, you can not scale the first clip larger than 800 px in width (output clip on your desktop). for clip >=2, that is no problem...
