midi mapping erased
    p8guitar
    midi mapping erased
    by p8guitar » Tue Dec 19, 2006 10:40 pm
    I spend several hours some days ago to assign a lot of midi mappings.
    Today I open the project and there is no mapping any more - nada, nothing, nix.
    :shock:
    Had someone similiar problems with v2.5 already?
    Peter
    P.S.: Apart from that - v2.5 is a great update! I like the new filter and bpm modules a lot.
    (Modul8 2.5.4, Mac OS 10.4.9, iMac 2.33GHz Intel Core 2 duo / 2GB RAM; MIDI: RME fireface 800, Novation Remote ZSL, Korg microKontrol, Faderfox LV2 and LX2. )
  • moonbase
    by moonbase » Wed Dec 20, 2006 1:13 am
    I guess you saved the project yes?
    If yes go to Preferences/ - Key/Midi Mapping and use Document Configuration.
    Preferences - Key/Midi Mapping is where you need to look I reckon. :D
    p8guitar
    by p8guitar » Wed Dec 20, 2006 8:46 pm
    the document configuration is saved, but the default configuration is not, this is a severe bug I think. close modul8 and open again, and the default configuration is blank, no midi mapping at all. Or change from default to document and back again, and you will also loose your default midi mapping, even without closing the application.
    cal6n
    by cal6n » Thu Dec 21, 2006 2:30 pm
    Did you "Save map as default" from the mapping menu? The default map is blank and then you have to save any changes you make to it.
    p8guitar
    by p8guitar » Thu Dec 21, 2006 6:52 pm
    Ah! :D no, I didn't see the save as default, that was my mistake. now it works, thanks a lot!
