A/B layer groups: group B only 1 layer set?
    p8guitar
    by p8guitar » Tue Dec 19, 2006 10:55 pm
    When I use A/B layer groups (crossfader enabled), the second layer group doesn't change with changing the layer set. Bug or feature?
    (Modul8 2.5.4, Mac OS 10.4.9, iMac 2.33GHz Intel Core 2 duo / 2GB RAM; MIDI: RME fireface 800, Novation Remote ZSL, Korg microKontrol, Faderfox LV2 and LX2. )
  • moonbase
    by moonbase » Wed Dec 20, 2006 1:25 am
    I'm not at my M8 machine but I'm pretty sure that clicking on a top 'layer set' tab
    doesn't change the bottom 'layer set' tab even without the crossfader enabled? - If I understand you right.
    This effectively gives you 16 'layer sets' of 5 layers to play around with.
    This can be really useful for involved gigs, 5 layers goes a long way, and it can also give
    some great 'fading' effects when you change sets ...
    especially if you have a bit of trace in the mix. :D
    p8guitar
    by p8guitar » Wed Dec 20, 2006 8:24 pm
    ehm... I actally didn't see the tabs at the bottom. they work...
    :oops:
  • moonbase
    by moonbase » Wed Dec 20, 2006 8:47 pm
    No worries :)
