problem whwn i play five layers at the same time
  • trovkio
    by trovkio » Thu Dec 21, 2006 7:40 pm
    hello, i'm very new with the soft. i need to play five layers simultaneously. I can't do it from the control panel. I asume that
    you have to build a modul for this?
  • bratch
    by bratch » Thu Dec 21, 2006 7:55 pm
    well, you can set the master speed at zero on a set with your 5 layers, and then, push "reset" button so all your layers start together.Hope it will be useful for you.
  • trovkio
    by trovkio » Thu Dec 21, 2006 8:16 pm
    i'll try that, thank in advance
