Midi mapping FILTERS ON/OFF
    VJ_JeSs
    by VJ_JeSs » Wed Jan 10, 2007 4:45 pm
    I can't find a way of mapping the "ENABLED" button on the filter module for different layers. If I map it for layer 1 (in midi map position mode). Ant then got to layer 2 it will replace my layer 1 setting !!!!
    Is there a way of putting filter effects on/off for different layers with MIDI ?
    Thx
    And by the way, it seems to be the same problem with any parameter in the filter module.
    VJ_JeSs
    by VJ_JeSs » Thu Jan 11, 2007 1:32 pm
    Boris, Yves ?? Is their an answer to this :)
    p8guitar
    by p8guitar » Sun Jan 21, 2007 4:33 pm
    Are you using the focus mode with midi mapping? then this behaviour is normal. try the position mode when midi mapping.
    Peter
  • TimeSquid
    by TimeSquid » Fri Nov 12, 2010 11:11 am
    bump...
    I dont think its possible, the focus-Position-Layerset position mapping options do not apply to modules.
    Any alternatives
    birdiedaboy
    by birdiedaboy » Fri Feb 04, 2011 6:11 am
    have you tried the 2 way midi from udart? maybe that can help im not sure though...
    Repeat after me: I am free
