Akai MPD16 + MIDI Question
    transoptic
    by transoptic » Sat Jan 13, 2007 5:50 pm
    Is anyone using the Akai MPD16? it seems that it might be ideal for clip-switching, with the 4 x 4 rows of pads. And it's relatively inexpensive.
    I'm looking for a controller to accompany my UC-33e...
    Also, with two USB controllers, is it possible to just daisy-chain them together with a MIDI cable, rather than having to also plug the second one in via USB?
    I'm sort of new to MIDI, so thanks for any help!
    Cheers!
    by vanakaru » Tue Jan 16, 2007 12:12 am
    i am going to get this drumpad too. I have run two midi triggers into one usb and into separate ones. made no difference as i was able to tell.
    also i used old kiti kat drum brain with piezo triggers to trigger clps to the beat.
    transoptic
    by transoptic » Sat Jan 20, 2007 2:34 am
    ...the MPD-24 looks pretty cool too, but I'm not sure if it's worth the extra 100€.
    it does have a row of 6 faders.... which might be useful since they are close to the pads you'd trigger clips with.
