How can convert my swf video to quicktime?
  • demon
    by demon » Fri Jan 19, 2007 6:20 pm
    Hi, i'm italian guy!
    i was pc user and now i buy a mac!
    i tryed to use modul8 but it doesn't support swf video...
    My database has a lot of swf video created with flash v. 7-8....
    how can i convert these videos to quicktime?
    there is a software to do this?
    Thx and sorry for my english!
    fati.V
    by fati.V » Fri Jan 19, 2007 7:36 pm
    hello,
    With Flash you can export vidéo, choose QuickTime... animation+ if you want transparency or Photo Jpeg (512/384)
    Or if you export under Flash 5 format it can be read by quicktime/modul8...
    There is a lot of topic about this :wink:
    Sorry for my english :oops:
  • demon
    by demon » Mon Jan 22, 2007 1:22 am
    thx... but I find a software can convert 500 video swf....
    fati.V
    by fati.V » Mon Jan 22, 2007 10:36 am
    You can give the name? :roll:
  • demon
    by demon » Mon Jan 22, 2007 5:03 pm
    Sorry.... wrong word....
    I didn't found... i'looking for the software can convert a lot of video in once time
    by sigmasix » Tue Jan 23, 2007 1:21 pm
    maybe an automator script can do that for you 8)
  • demon
    by demon » Tue Jan 23, 2007 1:27 pm
    yes.... but... who edit the automator script?
    by sigmasix » Tue Jan 23, 2007 3:15 pm
    you :idea:
    I can't help you actually, I don't really know automator but you should give a try, It's a really intuitive way to make scripts
  • demon
    by demon » Tue Jan 23, 2007 3:23 pm
    ummmm.
    thx... ican try...
    when i will find a tool convert swf....
    quick time can convert only swf v.5 .....
    i have a lot of swf v.7-8... :shock:
  • moonbase
    by moonbase » Tue Jan 23, 2007 9:15 pm
    Hi, I don't use Flash but I reckon there is a problem/issue with Flash in QT after QT 7.1.3. or thereabouts...?!
    Automator is great but so far I have only found 'QT' Actions within Automator (for moving image stuff) which means Flash conversion probably isn't supported as it is a problem from within QT itself - someone can put me right here, I'm bordering on 'out of my depth'.
    More usefully -
    This - http://www.flash-on-tv.com/flash-to-video.html - may be $40 well spent as it seems to support batch Flash to .mov conversion, haven't tried it but just Googled it for you.
    I found it on this Blog http://videos-flash.blogspot.com/ which looks useful.
    I initially thought http://www.ffmpegx.com/index.html may be able to help you but it looks not.
    Automator
    I am starting to enjoy Automator. If you haven't tried it yet give it a go.
    I can't programme but have made a couple of Automator actions to batch rotate still images 90 degrees left or right, which is always a pain in the workshops I run, it saves the originals to a seperate file, takes just a second and is available as an Automator plug-in right-click from Finder anytime - wicked.
    Also I have an Automator plug-in to find .movs with key words in the titles and then display the result in Safari which can be paged through.
    There are various Automator actions http://www.apple.com/downloads/macosx/automator/
    available for free or share from Apple. there are some realy useful freeware Photoshop Actions here.
    I blogged some stuff about Automator. Nothing that isn't in this post-
    http://moongold.me.uk/moonblog/2007/1/3 ... ssing.html
    Hope that helps - Enjoy - :-)
  • moonbase
    by moonbase » Tue Jan 23, 2007 9:40 pm
    Sorry, that Flash to Video converter doesn't appear to convert to .mov! ! ! what
    B****r - Seems crazy, but go to .avi or whatever... then use something like the Livid Union Batch to get to .mov.
    http://www.lividinstruments.com/software.php
    I'm waiting for one of you converter genius to come up with a simple obvious solution - Oh how I miss my Occams Razor.
  • demon
    by demon » Tue Jan 23, 2007 10:57 pm
    sorry but the Batch converter of Livid Union doesn't support swf 8...
    fati.V
    by fati.V » Wed Jan 24, 2007 7:51 pm
    download the demo of Flash8 on the adobe/macromedia site...
    And you have one month to convert your Flash movies...
  • demon
    by demon » Wed Jan 24, 2007 7:57 pm
    @ fati.V
    by sigmasix » Wed Jan 24, 2007 8:18 pm
    in flash, import your .swf file (if you still have the .fla it's better) then file>export>export animation...
    Then comes the idea of Automator to convert all your 500 files in one click but don't know how to do that... maybe even with apple script it's possible
