Clips Chocking in 2.5
  • jean-louis
    by jean-louis » Fri Jan 19, 2007 11:29 pm
    The very same clips that work perfectly on the previous version are chocking on the new one.
    I use Powerbook 1.64 runing OS Tiger
    What happens?
  • Donleavy
    by Donleavy » Tue Jan 23, 2007 11:49 pm
    I too find that the new version is slower than the previous ones. Just a couple of movie clips loaded and they start to stutter. Anyone else ?
    /Donleavy
    (PowerBook 1.67)
  • stuart
    by stuart » Fri Jan 26, 2007 2:17 am
    Me Too.
    I just upgraded to Tiger and launched 2.5 for the first time. I loaded a set and it was the worst performence I have ever seen.
  • jean-louis
    by jean-louis » Fri Jan 26, 2007 9:12 pm
    there is a weird thing happening...when i launch a project from version 2, the clips chock....when i load the very same clips on a new project, everything seems to be ok...
    go figure...
  • stuart
    by stuart » Fri Jan 26, 2007 9:35 pm
    I've not been so lucky. I dragged a handful of clips into a new project and it still choked.
  • 3Din2D
    by 3Din2D » Thu Feb 15, 2007 8:56 pm
    Chokes here too. Check your memory usage - use 'activity monitor' and report here what the application's actual/virtual memory usage is. Mine pretty much saturates memory with only a handful of short clips, which isn't supposed to happen.
  • moonbase
    by moonbase » Thu Feb 15, 2007 10:46 pm
    What versions of M8 are you all using please - i.e. 2.5.0 or 2.5.1 or 2.5.2? thanks :)
  • RickRobiN
    by RickRobiN » Fri Feb 16, 2007 8:08 pm
    What is the besr version to use (fastest? (worked for months with beta 3 without troubles.._)
    2.5? 2.5.2?
    cheers RR
    (sorry double post ;)
  • 3Din2D
    by 3Din2D » Sat Feb 17, 2007 2:35 am
    2.5? 2.5.2?
    cheers RR
    None of the 2.5.x versions have worked well for me; on long VJ sets I still use 2.0.2.
  • moonbase
    by moonbase » Sat Feb 17, 2007 3:26 am
    Same here - 2.0.2 on an iBook G4 OSX 10.4.8 is the only sure way at the moment for me.
    2.5.0 & 2.5.2 both choke very quickly, 2.5.2 can even get hung up totally and resists force quitting with a vengance.
    I've just finished a week long series of workshops with M8 in action all day every day -
    on tuesday & wednesday afternoons the last group of the day had every layer of their set 'lock-up' in 2.5.0.
    The other layer sets they had ready to go also showed 'loading' but never did.
    Thursday and friday have gone swimmingly on 2.0.2
    What the heck is beta 3 ??
  • RickRobiN
    by RickRobiN » Sat Feb 17, 2007 5:29 am
    beta, version 3. (versions before official release)
    Did some 9 hours gigs with it without problems. Got a big one 2morrow. Still not sure with one to use. I think the first official release of 2.5 seems okay... 2.5.2 is :evil:
    If someone has the answer which one is the best, please post it !
    cheers RR
  • moonbase
    by moonbase » Sat Feb 17, 2007 3:45 pm
    So that's what beta means, thanks, I had been wondering about that for ages! :D
    Just for interest, why are you using a 'version before official release' which I guess must be 3 years old now?
    Didn't we get version 1 of Modul8 in the middle of 2004 or something?!
    Somebody did - either go with answer one:
    or answer two:
  • RickRobiN
    by RickRobiN » Sat Feb 17, 2007 5:22 pm
    Intel machine here, so no 2.0 for me... (2,5 is intel update..;)
    cheers RR
  • pettedemon
    by pettedemon » Mon Mar 12, 2007 3:25 am
    cheers RR
    sorry if i ask you, but where do you find the 3 beta version?
  • RickRobiN
    by RickRobiN » Mon Mar 12, 2007 5:42 pm
    Beta is not here of course after an offical release,,,,
    I found out it was no difference about the versions 2.5./(beta whatever) or the official release 2.5.0
    It was about running 2.5 on a old not intel imac machine. There are more posts about this on the forum..
    cheers RR
Users browsing this forum: Baidu [Spider] and 29 guests
