FocusPosition in Network Global ?
    TheraBylerm
    by TheraBylerm » Sat Jan 27, 2007 3:37 am
    I'm using the module "network global"... everything works fine, except one thing (and it's very, very upseting !)
    I don't know how to turn off the informations relative to the FocusPosition. In fact, I'm trying to desactivate these informations... but it must keep sending information relative to the layer.
    I wrote some more lines, in the existing module that gives nothing... (I'm not good at Python, so sorry...)
    I put this line in the "init()"
    Code: Select all
    elif key.startswith ('ctrl_layerStack_focusPosition') and dictKey['keyFocusPosition'] : return (False)
    and this line in the "message event"
    Code: Select all
    elif msg == 'FOCUSPOS' : dictKey['keyFocusPosition'] = param['value']
    Any idea ? I'm feeling alone with my problem... :oops:
    by boris » Mon Jan 29, 2007 4:04 am
    Hum your code is completly wrong... (sorry)...
    A simple way is :
    change this ( line 30, init script) :
    Code: Select all
    elif key.startswith ('ctrl_layer') and dictKey['keyLayer'] : return (True)
    By :
    Code: Select all
    elif key.startswith ('ctrl_layer_') and dictKey['keyLayer'] : return (True)
    Juste add '_' and the keywords ctrl_layerStack... will be ignored !
    I will upload a new network module soon, with new filering key ![/code]
    TheraBylerm
    by TheraBylerm » Mon Jan 29, 2007 9:32 am
    :oops: I'm newb... I'm sorry... I will correct it !!
    by boris » Mon Jan 29, 2007 12:42 pm
    A new network module (v1.1) is online now !
    TheraBylerm
    by TheraBylerm » Tue Jan 30, 2007 12:24 am
    YESSSSS !!!!! It's perfect !!!!
    Thanks, Boris... !
