can't put layers on
  • das ist
    can't put layers on
    by das ist » Sun Jan 28, 2007 11:19 pm
    I've installed the newest version of modul8: V251. The problem i have now is that i can't turn the layers on.
    I've tried in a new document and also in an existing document and it won't work. A fraction of a second i see the movie, but the layer won't turn on. While in the preview-screen i can see the movie when it is put on the layer-tab. (i've also tested the existing document with V25 beta and there i can turn the layers on and off as it should)
    Is there anyone who regonizes the problem and knows the solution to this problem??
    with kind regards Niek.
  • ylandsman
    by ylandsman » Mon Jan 29, 2007 12:19 am
    Have you made sure that the color knobs are turned up?
    by boris » Mon Jan 29, 2007 2:59 am
    Check your modules, the problem is probably there.
  • das ist
    by das ist » Mon Jan 29, 2007 1:14 pm
    The module: layer-selector was active.
    thank you
