not importing .swf from PC
  • Guest
    by Guest » Tue Dec 14, 2004 3:03 pm
    I have problem importing swf-files made on a PC. They have their extension and the finder recognices their format and opens them fine. I ran a test on them saved as Flash 6 and published as 5, and another one saved as 5 and published as 5. Both, but at least the latter should work, but apparently the "Media is not supported". Would I have to open them all up in flash on my mac and save them, or is there something I can do?
    Best
    fatherMorgana
    yves@garagecube
    Re: not importing .swf from PC
    by yves@garagecube » Tue Dec 14, 2004 7:05 pm
    It should work... AFAIK there is no difference between a PC swf or a Mac one. Try to open it using Quicktime to see if it works. You can also send us the file (support [at] garagecube.com) so we can see what's going on.
    Yves.
