Modul8 V2.5.2 Released - Strongly recommanded update
    yves@garagecube
    by yves@garagecube » Wed Feb 07, 2007 3:40 pm
    A new version of Modul8 is available right now.
    A problem in the V2.5.1 may cause Modul8 to stop working at all. This is a strongly recommanded update.
    You can download it using the regular update mechanism (from the Modul8 menu).
    Changes:
    - Fixed a problem in the registration mechanism which may cause Modul8 to stop working.
    - All mono-core/processor system uses a specialized path in the engine for better performances
    - Movies are always rendered at the correct pixel size even if they were saved scaled from the Quicktime player.
    - Fixed an issue which may corrupt documents after a logical record was done.
    - Fixed an issue which may prevent the logical record to play back correctly
    xrayconcept
    by xrayconcept » Sun Feb 11, 2007 4:29 pm
    Thank you for working on this new version..
    The improvement is clearly good especially for the logical render wich is working normally now..
    A +
    Pixray > xray concept
    Xray C Blog
