iconize new versions
  • Lupin
    by Lupin » Wed Feb 07, 2007 5:49 pm
    Hi since you changed the background picture of the modul8 folder, i think it could be a good thing you also change the icon for the M8 application (it's the same as the 2.03 version) and it could be also helpfull to add a Version number on it
    ciao
    by sigmasix » Wed Feb 07, 2007 10:30 pm
    and also think about a (THE) new testcard 8)
    by ilan » Sun Feb 25, 2007 3:42 pm
    We could have a competition for it. The person that designs the best test card and icon receives something. modul8 t-shirts? A license? Chocolate? A chocolate licensed t-shirt :D
  • deckard97
    by deckard97 » Thu Mar 20, 2008 2:06 am
    Is the current Modul8 Testcard available in higher resolutions?
    If you (the Modul8 developpers), have designed this current testcard in vector format (Freehand, Illustrator) you could send me the file and I could make updates at varying resolutions.
    Thanks.
    by sigmasix » Thu Mar 20, 2008 9:53 am
    try this ;)
    http://dev.sigma6.ch/
    and it's only the beginning, I'll update the software someday with other standard test patterns, but objective-c is not easy :roll:
    by vanakaru » Thu Mar 20, 2008 10:25 am
    thank you for this, sigma6. very nice indeed!
    and I like modul logo alot. it is the most simple but still informative app logo of all my apps.
  • deckard97
    by deckard97 » Thu Mar 20, 2008 2:42 pm
    Wow, nice idea.
    But, would it be possible top obtain the source vector file of your testcard because I realy need one in Modul8 at specified resolutions for testing purposes.
    Thanks and great job.
    by sigmasix » Thu Mar 20, 2008 3:53 pm
    there is no vector file for what I've done, it's 100% code to fit any ratio... It's not that hard to redo it in illustrator, you should give a try yourself, then you can have exactly what you want...
    wygiwys
    by wygiwys » Thu Mar 20, 2008 6:38 pm
    A competition would be nice!
    You've got a program on the internet which can turn (not too complicated) images into vector's.
    I can give you the name if you would like, otherwise google it (it's a project from a university)
    What You Get Is What You See
    WYGIWYS.tv
    cheveria
    by cheveria » Fri Mar 21, 2008 5:42 pm
    Yeah, give us the name of the software to convert to vector.
    i know you can use Trace in illustrator.
    SO MODUL8 CREW? Do we have a competition or what?
