Performance Problem with Modul8 2.5.2
    yves@garagecube
    by yves@garagecube » Mon Feb 19, 2007 2:38 pm
    It seems that some users are experiencing performance problems with Modul8 V2.5 on mono-processors machines (especially on G4 1.67 and on G5 mono-core/processor).
    We are interested by projects that are significantly faster on Modul8 V2.0 comparing to V2.5.
    Please do not send us report for the V2.5.0 or V2.5.1. First of all you should install the V2.5.2 and if you still have performance problems then:
    Send to support[at]garagecube.com:
    - A system profile (Go to "Apple menu -> About This Mac -> More Info..." Then choose "Save As" to get the profile file).
    - If possible a link to a project (including media) that was working well on V2.0 and which does not work anymore on the V2.5.2.
    - If you cannot send us a project, please describe as precisely as possible the project you have and the kind of speed problems you are experiencing
    We are looking for serious speed hit, not marginal slow down. The V2.5 is a new engine with support for several new technologies like FreeFrame or CoreImage and in some cases it may be slower than V2.0. However it should not be slower to the point that a project does not work at all.
    Thank you for your help.
    Yves
