memory usage
  • jean-louis
    memory usage
    by jean-louis » Mon Feb 26, 2007 11:55 pm
    i use a powerbook g4 167 with a 64mb graphics card, and 1.5gb ram. What are the numbers for memory usage i should put on the preferences menu in order to get better performance?
    Most my clips are 640x480 30fps around 200MB in size.
    thanks
  • 3Din2D
    Re: memory usage
    by 3Din2D » Thu Mar 01, 2007 4:54 am
    thanks
    First, which version of modul8 are you using? Secondly, how many of your clips do you usually use and in which format?
  • jean-louis
    by jean-louis » Fri Mar 02, 2007 10:47 pm
    using version 2.5.2
    clips: load 8 layers at a time, they are .mov photo-jpeg codec
  • 3Din2D
    by 3Din2D » Thu Mar 08, 2007 3:16 am
    using version 2.5.2
    I've noticed in 2.5.2 that it loads some medias uncompressed into RAM - take a look in your media inspector and set the medias to load compressed/from disk. Hopefully this will be resolved in 2.5.3.
