Suggestion for a future version
  • ylandsman
    by ylandsman » Thu Mar 01, 2007 1:02 am
    It would be nice to have a single layer that when turned on would be the frontmost layer for both group a & b. This would be useful for having mask images that are constant in each group.
  • videoteque
    by videoteque » Thu Mar 01, 2007 8:29 am
    Do you mean like a Master/Output layer??
    IMHO it would be nice to have a layer that is the output, so you can effect/mask/colorize the whole mix of layers.
    Another great feature would be to copy the Output Fade of the Edirol V4, it's great to make fades, but also to control the whole brightness...
  • ylandsman
    by ylandsman » Thu Mar 01, 2007 8:35 am
    That would be awesome, as would be a mask layer. What I meant though was much simpler. Merely a layer that would sit on top of both group a and group b. This would allow me to create a black mask for example with holes in it that would show the layers underneath.
    by sigmasix » Sat Mar 03, 2007 2:56 pm
    guys, there's a module to select a layer as a mask or foreground layer menu: Modules>Show>Mask (global)
  • ylandsman
    by ylandsman » Sun Mar 04, 2007 3:07 am
    thank u that's exactly what I was talking about
