Sound Viewer module CPU usage (2.5.2)
  • 3Din2D
    by 3Din2D » Thu Mar 01, 2007 6:04 am
    We've been designing a new module and noticed that modules can take a considerable amount of CPU when enabled.
    The '(vs) Sound Viewer (Tool)' module for example adds 10% to modul8's CPU consumption on a 2GHz G5 CPU just for monitoring audio. Is this normal?
    yves@garagecube
    Re: Sound Viewer module CPU usage (2.5.2)
    by yves@garagecube » Fri Mar 02, 2007 9:37 am
    It depends of what your module is doing, especially in the "Periodical" script. This script is called typically at 60HZ and if you are doing a lot of processing it may take a lot of CPU.
    Something you can do in your module is to put a timer based on the Periodical elasped value and call your function every X milliseconds instead of at each render tick.
    Now I did a lot of optimization for the soon to be released V2.5.3 which reduces the overhead of the module, especially when you have a lot of controls. Hopefully it will help.
    Yves.
  • 3Din2D
    by 3Din2D » Sat Mar 03, 2007 2:42 am
    Yves.
    Ok, although the module I refer to above is supplied with modul8.
    In a strange turn of events I'm working with the guy who did the review and the programmer dude from the collective and we'll be releasing a module that will add a certain hardware device ;)
    Is there any documentation we can use in reference to the Python scripting? A lot of the code was figured out by the programmer 'hacking out' bits of code from other modules.
    by boris » Sat Mar 03, 2007 3:37 am
    NO, this module is NOT supplied with modul8.
    This module is from a Modul8 user.
    -> Author : VisionSonor
    PLEASE NOTE :
    Modules from users are not guaranteed by GarageCUBE use at your risk !
    "GarageCUBE Library" means Modules from GarageCUBE
    "Public Library" means Modules from Users
    yves@garagecube
    by yves@garagecube » Sat Mar 03, 2007 10:14 am
    Check the Modul8 documentation. There is an introduction to Python and a description of all the available functions for module scripting.
    You can also find more general information regarding Python at www.python.org
    Yves.
  • 3Din2D
    by 3Din2D » Thu Mar 08, 2007 4:11 am
    Yves.
    Yeah he's seen that - but we've seem to come across a bit of a problem - we're capturing a MIDI controller and want to route the transformed output so it can be generally used - so, for example, we receive a Continuous Controller, at the moment we can only get it to affect a direct element in the system, like movie position. We would like it to be universal, like this:
    As it stands now, we can only do this:
    MIDI controller -> is captured in script -> modifies movie time
    But we want to do this:
    MIDI controller -> is captured in script -> modifies 'value'
    But we can't seem to do it and can't find anywhere in the documentation how to.
  • Lupin
    by Lupin » Tue Mar 27, 2007 8:19 pm
    (VS) Sound Viewer module has been updated. the refresh rate of the module is set to 1/4 seconds
    enjoy again
