Acces Layer Filter via other module
  • AZK
    by AZK » Fri Mar 02, 2007 6:22 pm
    I'm not a great coder but i use to write my own modules for clip triggering and i'd like to know if it's possible to access the layer filter module from an other module to trigger specific effects and their parameters at the same time as one clip.
    I already do that with the pixel FX, for instance.
    Thanks for any insight,
    AZK
    Aïzenko :: Motion Graphics - Web Applications - Live & Interactive Exhibitions
    www.aizenko.com
    Re: Acces Layer Filter via other module
    by boris » Fri Mar 02, 2007 7:14 pm
    Is it possible, but not really simple.
    You need to modify the filter module for that.
    A better way is to integrate filters directly on your own module.
    AZK
  • AZK
    Ok,
    by AZK » Fri Mar 09, 2007 12:32 am
    I'm not so familiar with python, so how can i do that ?
    Simple cut and paste ?
    Thanks,
    AZK
    www.aizenko.com
