CI Image Units
  • ylandsman
    CI Image Units
    by ylandsman » Tue Mar 06, 2007 12:40 am
    Can third party core image image units be used with modul8? If so, how do I activate them? I have tried with the plugin file in the /Library/Graphics/Image Units/ directory, and I have tried putting the plugin file in the modul8 plugin directory. Neither seem to work, although with the plugin in the /Library... directory they are recognizable in quartz composer.
  • ylandsman
    by ylandsman » Fri Mar 23, 2007 9:02 pm
    Yyves, Boris, can either one of you give me the word on this, I would love to add some new image units, but don't want to purchase them until I know that m8 can support them.
    yves@garagecube
    by yves@garagecube » Thu Mar 29, 2007 5:10 pm
    Well you should be able to use external ImageUnits. Modul8 simply asks CoreImage for the available filters, so it is 100% dynamic.
    Now please note that Modul8 does not support filters with more than one source (yet).
    Did you see it in other applications (like QuartzComposer) ?
    Yves.
  • ylandsman
    by ylandsman » Thu Mar 29, 2007 7:14 pm
    Yes I did, I'll go back and make sure that the filter was one source
    yves@garagecube
    by yves@garagecube » Mon Apr 02, 2007 4:09 pm
    You are right there is a problem with the current version of Modul8 regarding external filters. It will be fixed in the next release.
