midi mappings for Faderfox controllers
  • brain
    by brain » Mon Mar 19, 2007 3:35 pm
    dear fellow M8 users,
    i have created suggestions on how to set up two Faderfox controllers for Modul8. you can download these here: http://eyetrap.net/hardware/index.html
    Faderfox has a modular approach, so i decided to combine two controllers:
    - one for global controls like master speed, master size, A/B mix etc. and
    - the LD2 for layer-specific parameters. because of its endless encoders its well suited for switching layers.
    currently i am working on a setup for the DJ2 as an alternative for global controls. a PDF with a setup will be available soon. unfortunately it is not yet possible to export midi settings in Modul8; so you will have to re-create the setups in the app. anyway, the setup suggestions are just a starting point to do your own style...
    you may want to check my short hardware reviews on the controllers here:
    http://www.vjcentral.com/?act=search&qu ... e=hardware
  • brain
    New mapping for faderfox DJ2
    by brain » Tue Apr 10, 2007 9:31 pm
    Hi folks,
    there is now a third mapping online: for the DJ2. I use this controller for the global controls. Great tool! http://www.eyetrap.net/hardware/index.html
    The setup is just a suggestion; you may come up with other ideas...
    Maybe you want to have a peek. Feel free to ask any questions. Comments appreciated.
