Logical Record without Sound?
  • VD Sadigh
    by VD Sadigh » Wed Mar 21, 2007 2:15 pm
    Hi
    I use M8 for 3 Months. I like to make a logical record with sound. The rendering works fine, but i dont have any sound. :( Can you help me. Like to make a DVD with Clips and Sound...
    Greets form Stein
  • Lupin
    by Lupin » Wed Mar 21, 2007 9:30 pm
    if you wanna record your gig with audio you should plug your mac to a HDD DVD recorder or digital VCR like the archos 404 camcorder. it's the safest way to record your gig especially if you use a video mixer in addition to your mac.
  • VD Sadigh
    Ok, but...
    by VD Sadigh » Fri Mar 23, 2007 8:45 pm
    Is it not possible to make a record, and then to render it nativ witout any else Machine. I know this Funktion from Arkaos3.5. :roll:
    Greets from Stein
    Patrick
  • ylandsman
    by ylandsman » Fri Mar 23, 2007 8:59 pm
    From my experience, Arkaos is totally unable to record audio. M8 can, but not with the logical record.
  • Lupin
    Re: Ok, but...
    by Lupin » Sat Mar 24, 2007 2:11 pm
    Greets from Stein
    Patrick
    you miss read my answer i didn't mean arkaos but ARCHOS media recorder/player. it has none sens to use andthoer VJ software to do a logival record as long as you don't do the same video gig.
    the best way to record audio and video is tu use an external hardware device
Users browsing this forum: Baidu [Spider] and 18 guests
