PAL to NTSC
  • egilleland
    PAL to NTSC
    by egilleland » Fri Mar 23, 2007 11:43 pm
    Im outputing to a Panasonic AV5 that is NTSC. Im in Argentina and most everything else is PAL. Im sure that at some point I set Module to PAL because it works on my PAL monitor. How do I change it?
    My Skype name is egilleland too.
    yves@garagecube
    Re: PAL to NTSC
    by yves@garagecube » Thu Mar 29, 2007 5:14 pm
    egilleland wrote:Im outputing to a Panasonic AV5 that is NTSC. Im in Argentina and most everything else is PAL. Im sure that at some point I set Module to PAL because it works on my PAL monitor. How do I change it?
    Modul8 never changes the resolution of the output. You should change it yourself in the system preferences.
  • egilleland
    by egilleland » Thu Mar 29, 2007 6:09 pm
    I assumed that it would be in system preferences. However I dont see anything that indicates where those changes can be made. What submenu deals with output resolution?
    by sigmasix » Fri Mar 30, 2007 9:10 am
    you must have an external screen/projector plugged in yourr computer. then go to system preferences > monitors and change the resolution of your output!
