Modul8 V2.5.4 released
    by boris » Thu Mar 29, 2007 1:44 pm
    A new version of Modul8 has been released today (V2.5.4) !
    All Modul8 registered users can download this new release directly from the Modul8 menu (you need to use Modul8 V2.01 or higher)
    A demo version is also available online right now.
    V2.5.4
    - Fixed : problem with the logical record rendering when clip would play backwards
    - Fixed : local layer record was not saved in the document
    - Fixed : problem on global record and direct keyword
    - Fixed : problem with the matrix effect and multiprojection (advanced output)
    - Update : Module Text and Module Movie Scratch
    V2.5.3
    - Many optimizations
    - Improved path for G4/G5
    - Fixed an issue where Modul8 was not playing a movie after very fast media triggering
    - Workaround for Quicktime 7.1.5 problem with CoreVideo.
    V2.5.2
    - Fixed a problem in the registration mechanism which may cause Modul8 to stop working.
    - All mono-core/processor system uses a specialized path in the engine for better performances
    - Movies are always rendered at the correct pixel size even if they were saved scaled from the Quicktime player.
    - Fixed an issue which may corrupt documents after a logical record was done.
    - Fixed an issue which may prevent the logical record to play back correctly
    V2.5.1
    - added : Free ratio in the preview window (preferences)
    - adeed : Sound smooth option (off by default)
    - fixed : False midi stamp on PPC computers (used for midi clock on the BPM module)
    - fixed : A minor problem with workspace and media window
  • singer
    Quartz Problem
    by singer » Tue Apr 03, 2007 5:21 am
    Hey there,
    I just noticed that there seems to be a major performance loss for quartz compositions in versions 2.53 & 2.54
    2.52 is still fine, quartz comps play full speed, but it looks like in the newer versions, I only get about 10fps no matter what composition I use, even very simple ones.
    All preferences are the same in all versions, I'm on a mac book pro 2.0, 2BG of ram, ATI radeon x1600 256mb, os 10.4.9
    Thanks
    Adam
    yves@garagecube
    Re: Quartz Problem
    by yves@garagecube » Tue Apr 03, 2007 8:51 am
    What version of Quicktime are you using ?
    Yves.
  • singer
    by singer » Wed Apr 04, 2007 12:31 am
    7.1.5 pro
    yves@garagecube
    by yves@garagecube » Fri Apr 06, 2007 9:26 am
    7.1.5 pro
    There is a problem with this QT version which forces us to turn off CoreVideo acceleration in this context. Apple knows about this problem and hopefully they will release a fix soon.
    In the meantime, the only solution would be downgrade to 7.1.3.
    Yves.
  • singer
    by singer » Fri Apr 06, 2007 9:06 pm
    thanks for the info
  • Mathieu St-Arnaud
    by Mathieu St-Arnaud » Thu Jun 14, 2007 7:33 pm
    Hello !
    Is Quicktime 7.1.3 still the one to use or is 7.1.6 ok ?
    m.
  • bratch
    by bratch » Fri Jun 15, 2007 9:55 am
    Back on 7.1.3, i had trouble with multiprojection with 7.1.6.
    I'm on Mac Pro 2.66Ghz - 5 Giga RAM - HD RAID 0 - QT 7.1.3 - M8 2.5.4
  • keptnahab
    by keptnahab » Sat Jun 16, 2007 7:03 pm
    where can i get qt 7.1.3 ? cant find it on apple.com
    i have a brandnew macpro with qt 7.1.5 installed...
    by sigmasix » Tue Jun 19, 2007 11:56 am
    dont be afraid of quicktime, I don't know what's the matter with it but I use the laste version of quicktime and don't see any problems... but maybe it happens with things I don't use in modul8...
  • bratch
    by bratch » Tue Jun 19, 2007 1:16 pm
    what Mac have you got? G5 or Mac Pro? Isn't multiprojection broken ?
    by sigmasix » Tue Jun 19, 2007 4:15 pm
    I have a mac book pro actually, and I don't use multiprojection... I'm running the last version of mac OS and last version of modul8 and the latest version of quicktime.
  • bratch
    by bratch » Tue Jun 19, 2007 6:16 pm
    It was working fine with a single projection for me, but not on multi projection. Maybe it's because i had 3 Nvidia cards and 1 ATI.Does anyone use multiprojection with quicktime 7.1.6? does it work? Anyway, Yves told me that multiprojection was broken under 7.1.6 as you can see down there.
    You were right, multiprojection is broken under QT V7.1.6. I'll try to find a workaround asap.
    Yves.
    http://www.garagecube.com/forum/viewtop ... sc&start=0
  • Akira
    by Akira » Tue Jul 03, 2007 11:28 am
    I still get this ANNOYING error:
    (photo taken in the middle of a 12k ppl high profile gig, serious f....! :P)
    iBook 32MB VRAM latest Tiger, m8 v2.5.4, QT 7.1.3
  • rola
    by rola » Mon Jan 07, 2008 9:11 am
    I will download the demo version to try it.
Users browsing this forum: No registered users and 59 guests
