Sync with LTC (Linear Time code)
  • AZK
    by AZK » Thu Apr 05, 2007 4:42 pm
    I was wondering if there was a way to connect modul8 to an external timecode generator to control clip triggering in modul8.
    For a show i need to sync modul8 and other systems (lights, sound, etc.).
    And last but not least, my clips will have a 1920x1080 resolution.
    Thanks for any insight.
    Cheers,
    AZK
    Aïzenko :: Motion Graphics - Web Applications - Live & Interactive Exhibitions
    www.aizenko.com
  • Augenkammer
    Re: Sync with LTC (Linear Time code)
    by Augenkammer » Wed Jan 15, 2020 5:50 pm
    I have the same question (but it is Jan 2020). Was there any answer? Did you solve your problem somehow?
    Regards // Friedrich
    by sigmasix » Tue Jan 28, 2020 10:05 am
    I've done an MTC mosule a few years back. Unfortunately, I can't upload it to the public library. It's not working. Probably because I'm still using modul8 2.9.2…
    Find the module attached.
    I must say I don't really remember how it works but we used it to sync a Logic or Cubase timeline with a movie.
    (s6) MTC.m8m.zip
    (4.15 KiB) Downloaded 2706 times
Users browsing this forum: No registered users and 46 guests
