problem using 50 fps quicktime movie
  • videomasta
    by videomasta » Thu Apr 05, 2007 5:56 pm
    hello modul8 user ! i am a newbie in this field. i have tons of "full format" dv movies and i want to play and mix them properly in modul8.
    first i tryed to play them directly without converting them.
    (my output has the same size as the movies)
    this worked fine for movies with fast changing content.
    for movies with slow, elegant movements ito it not :-(
    so i converted them into quicktime movies with foto jpg compression.
    for good results, i had to go to the double framerate to 50 fps. (i am living in a pal country)
    these movies were jerking in modul8, without applying any effects in modul8 !!
    i played them with the quicktime player through the second monitor out without
    problems.
    perhaps, somebody has an idea to solve this problem.
    perhaps an other codec etc.
    my system is: mbp, 2,16ghz intel core 2 duo, 2gb ram
    all the best from the videomasta !
