PLEASE HELP ME- I Need to lose the background
  • d.fran
    by d.fran » Thu Apr 12, 2007 5:36 pm
    Does anyone know a way prepairing footage so it has no background when bringing it into Modul8? I know about the Luma keys that can be used to eliminate black and white areas but my clips have lots of different colours including black and white and i don't want them to be effected. I have After Effects, Final cut, Premier and loads of other software to use to prepare it if it helps.
    PLEASE CAN ANYONE HELP? :(
    D.fran
  • Mathieu St-Arnaud
    by Mathieu St-Arnaud » Thu Apr 12, 2007 7:07 pm
    render using the Animation+ codec (i do this from Ater Effect all the time) ?
    m.
  • d.fran
    by d.fran » Fri Apr 13, 2007 4:10 pm
    Thanks so much, i haven't tried it yet as my powerbook is being fixed at the moment. but thank you for the quick reply i'll try it as soon as i can.
    D.fran
Users browsing this forum: Baidu [Spider] and 19 guests
