J'ai 4 cartes graphiques (3 cartes 7300GT et 1 carte X1900XT)If you have more than one graphic card in your Mac and you are using only two outputs (one for the interface and one for the composition) you should always connect the two outputs to the same graphic cards.
Yves.
I'll do my best to find a solution during the week. If it takes longer, send an email to support[at]garagecube.com and I'll do a special build with the CoreVideo path disabled.Yes, i'm a bit worry cause i'm having a gig in a week so, i really hope this pb will be resolved![]()
And for french talking, i wouldn't have been able to explain it well in english, so...thanks Yves for translation
