MIDI INPUT EFFECT ASSIGN…
  • masomenos
    by masomenos » Sat May 05, 2007 2:58 pm
    HELLO,
    I've been using modul8 for a couple a month now, and figure out how it works better and better.
    I have an intelmac.
    I send my midi signal from live trough iac driver (= midipipe, but built in tiger)
    Thanxs to "Print Direct Event" modul i can see midi is coming in M8 in the scripts:
    {'timestamp': 14753317886672.0, 'channel': 1, 'param1': 36, 'message': 'NOTE_ON', 'rawEvent': 144, 'param2': 100}
    {'timestamp': 14753442865795.0, 'channel': 1, 'param1': 36, 'message': 'NOTE_OFF', 'rawEvent': 128, 'param2': 64}
    NOW HERE IS MY QUESTION:
    How can i assign an action to that midi signal?
    Suppose, i want to to turn on auto scale on key down, and transformer on key up…
    how can i do that?
    thanxs a lot to anyone who took time to read this post…
    thanxs a lot lot to whom has an answer…
    joan
    yves@garagecube
    Re: MIDI INPUT EFFECT ASSIGN…
    by yves@garagecube » Mon May 07, 2007 11:42 am
    masomenos wrote:How can i assign an action to that midi signal?
    Midi mapping is here for this purpose. Module scripting is useful only when midi mapping does not allow you to do what you want.
    You should read the documentation. There is a whole section on midi mapping.
    Yves.
  • masomenos
    by masomenos » Mon May 07, 2007 12:49 pm
    Yves:
    merci pour votre reponse…
    j'ai lu la doumentation, mais il y a quelque chose qui m'echappe:
    je peux en effet assigner des actions à des touches de mon controleur midi ou a mon clavier sans soucis.
    Cependant, quand j'envoi de ableton live un signal midi, qui est pris en compte par modul8 (ce que je peux constater dans les scripts grace au module print direct event)
    comment faire pour lui assigner une action?
    est-ce que le module midi relativ exemple cree par boris est un exemple de script pour ce genre de signal midi?
    si oui, existe-t-il une base de donnée de scripts pour signal midi?
    je vais plancher un peu plus sur le scripting en attendant votre reponse
    j'espere que je suis assez claire…
    merci
    joan
  • masomenos
    by masomenos » Mon May 07, 2007 5:49 pm
    ok,
    grace au modul midi relativ exemple, j'ai compris et reussi a le faire marcher…
    maintenant le seul soucis c'est que je ne connais pas le "code" pour chaque partie.
    Dans le modul d'exemple j'ai ce code
    modul8.setValue('ctrl_layer_rotation_z', valuePrev,1)
    j'ai essayé de remplace rotation par scale mais ça ne marche pas…
    ou pourrais-je trouver une sorte de dictionaire des codes?
    Comment par exemple pourraisj-je nommer et controler la partie Disp.map dans le transformer?
    merci
    joan
