Video Card for PowerMac G4
  • JonesyJohnny
    by JonesyJohnny » Mon May 07, 2007 12:15 am
    I am still trying to figure out what the best video card for my system will be. I have a Powermac G4 that doesn't have dual monitor capabilites. Below is the one I plan on purchasing. I plan on just using one output. Do I need this? Can I go to a lower model and still be ok? If this isn't what I need any suggestions? Should I go PCI or AGP?
    This video card features :
    Fully functional VGA + DVI-I + S-Video ports (This card does not feature an ADC port and uses a standard VGA port instead of)
    Active fan cooling!
    Apple Quartz Extreme functionality and support
    Apple Core Image functionality and support
    Fully supported within Apple Motion and Aperture
    AGP 2x 4x 8x operation, works with Apple G4 & G5 Computers with AGP bus slot
    Works with Digital and/or Analog LCD and CRT monitors up to 30" with a max 3D display resolution of up to 2048x1536 @60Hz
    Extended display, Mirrored display and TV+VGA capable!
    Requirements :
    Apple G4 series and/or Apple G5 AGP equiped computers
    Sawtooth, Gigabit Ethernet, Digital Audio, QuickSilver, Mirrored Door, FireWire 800 and any other Apple G4 computer (except the Apple G4 Cube) as well as Apple G5 computers equiped with a AGP bus slot
    Mac OSX 10.2.5 and above needed for full functionality and support
    yves@garagecube
    Re: Video Card for PowerMac G4
    by yves@garagecube » Mon May 07, 2007 11:40 am
    On the G4 generation, you must use an AGP card.
    Yves.
    by vanakaru » Mon May 07, 2007 8:28 pm
    Please explain what I am missing when using PCI card. I have Radeon 9200 SE 128meg PCI working very good on G4 AGP Graphics. I used AGP 9600 too and do not remember anything different except this was much faster card..
