hello.... can layers be triggered by different QWERTY keys?
  • joshuapearson
    by joshuapearson » Thu May 17, 2007 6:25 pm
    i feel like i am trying to do something simple... i want to map one video clip to many different keys on my keypad, change its pitch(speed) slightly for each key, and then "jam" as if i was playing a true "video sampler"... can this be done with modul8? i can't seem to figure it out... when i try to re-map the layer on/off to different keys, it won't let me... each layer automatically gets the same key
    i realize i can trigger clips in the bin using different keys but does that mean i need to "pre-produce" the clips and pitch them up & down in other software, then import them into modul8? that seems silly...
    and i know that i CAN put the same clip in the 10 different layers and change their pitch/speed with the slider bar, but then i can't map those layers to different keys!
    --thanks for advice---
    --josh
  • ylandsman
    by ylandsman » Thu May 17, 2007 9:09 pm
    If you change the mapping mode to layerset, or position that should accomplish what you want to do.
