rendering problems with painter module
  • vanno
    by vanno » Sat May 19, 2007 3:01 am
    hello all. when i want to render a composition made with the logical recording option, the content in the painter module is emptied, i.e. the drawings made in the painter module are somehow erased. as soon as the rendering process starts, the layers containing the painter module display and 'empty layer message'. as a result, the rendered movie doesn't contain any of the painter graphics. any ideas on how to solve this?
    i'm using a lot of very simple vector-style elements in my work, the painter module is ideal for this, as it doesn't require me to load movies - i just draw whatever i need into a layer. however, i do need to export my work for further editing, so a solution would be appreciated.
    otherwise, m8 rocks. really.
    thx
    peter
  • nine09
    by nine09 » Sat May 26, 2007 1:41 pm
    i have the same problem. on top of it, after trying to render the image it remains visible in the painter pane but disappears from the preview pane....
    any help would be greatly appreciated !
  • cpt digital
    render problem painter
    by cpt digital » Mon Aug 20, 2007 5:50 pm
    hello,
    i also have this problem with my new Modul8V254
    why ?
    thx
  • moonbase
    by moonbase » Mon Oct 15, 2007 3:41 pm
    Thought I'd resurrect this thread as I've just come up against it also.
    Output from the Painter module just doesn't record out of M8 via logical record :(
    Crying here Boris - boo hoo - it would have been great and magic if it did :)
    If there is a fix a workaround or a bodge available for the Beta that would be magic also.
    Best.
    Baf
    by Baf » Mon Dec 31, 2007 12:33 am
    Hello world (?),
    Je n'est pas tout compris, mais cela ne m'empêche pas d'être d'accord... me too j'ai les mêmes problèmes avec painter. Si donc quelqu'un avait un début d'idée de bout de code de chose...
    Cela fait trois jours que j'utilise modul8, et que du bonheur, sauf que painter... allez demain je me met à Python -et à l'anglais-.
    Good day.
