chaos mode like in resolume?
  • MrRooh
    by MrRooh » Sun May 20, 2007 8:06 pm
    is there any module similar to the chaos mode in resolume?
    it would be nice if its possible to let the videos in layer one autochange. so you can conentrate on other stuff or eventually lay back for a moment and take a break ;)
  • progra
    by progra » Mon May 21, 2007 12:32 am
    if i understand right you maybe meen something like the "SLIDE SHOW (layer)" module.
    is in the garagecube library.
  • MrRooh
    by MrRooh » Fri May 25, 2007 11:05 am
    thanks works even better than resolume :)
  • spongemonkey
    by spongemonkey » Tue May 29, 2007 10:20 am
    i only wish Slideshow didn't try to play empty media banks.
    i tend to set up my projects with empty spots and fill em on the fly.
    so it does work well when slideshow plays a blank clips.
