isight compression
  • momo3010
    isight compression
    by momo3010 » Mon May 21, 2007 11:52 am
    Just playing around with my isght using to capture live painting. Somehow the output is quite niosy - especially when using contrast to make the drawn lines look more black.
    What compression settings are recommended to use isight in modul8? (codec?)
    by sigmasix » Mon May 21, 2007 3:05 pm
    I think the noise from the isight is coming from the isight not from the codec... the quality of the isight is fine if you have a lot of light... if you're inside with sun outside and no lights around you, it's already bad...
  • momo3010
    by momo3010 » Tue May 22, 2007 3:24 pm
    thanxs sigma6,
    will keep the isight for chatting. :-)
    by vanakaru » Thu May 24, 2007 1:42 am
    I got recently an old Panasonic F10 for live input. I am using Dazzle firewire box to get analog signal to Powerbook. There is some latency, but not too bad. And the picture is great.
  • momo3010
    by momo3010 » Mon May 28, 2007 12:00 am
    jeah!
    iam going to buy a little sony handcam in ebay.
    Sure better than isight, ... and it can record the whole painting
    process.
    Thats cool
