what's going on!! I know know
  • mowgli_uk
    by mowgli_uk » Mon May 28, 2007 11:57 pm
    I have a series of modul8 projects all containing this particular png image. For some strange reason every layer on every layer bank on the whole project keeps defaulting to this particular png which happens to be placed on the second place in the media bank. Or which is the same every layer in the project displays the same image.
    When I switch layer banks the correct clips and images are flashed very briefly before all the layers start displaying the same image.
    I've had one of this projects for months with everything working fine, its all happened suddenly. All the other projects with the same problem were created from the same original file.
    OK found the solution while writing this.
    The problem was caused by the "rotary my clips" module, once removed everything is back to normal!
  • viberation
    by viberation » Wed Jul 01, 2009 7:28 am
    This drove me crazy for about a month. I also figured out the Rotary My Clips module was a culprit. Removing it fixed everything.
    Below is a list of symptoms in case anyone else is searching for this.
    - Saved projects will open up with every layer displaying the same media clip, as opposed to the original media clips they were saved with
    - The redundant clip is in the Media Set position 2 (two), page 1 (one)
    - When you try to copy any layer, it will always copy with that same media clip (the wrong clip)
