mask using painter
  • Niall
    mask using painter
    by Niall » Thu May 31, 2007 5:37 pm
    does anyone know a way to have layers as masks? as in cutting out the layer below, like in photoshop. I need it to work with painter.
    We need to isolate live performers, and probabley can't fit in a blue screen or anything. So, our plan was to be able to draw a faint outline around someone with the paint module, and then use it to mask the layer beneath, if that makes sense.
    Does anyone know a way to do this?
    by sigmasix » Thu May 31, 2007 10:26 pm
    use the module called mask it doesn't take a layer to do that wich is good!
  • Niall
    by Niall » Mon Jun 04, 2007 4:36 pm
    I can't really find a way to get it to work like I want it to though, as I understood, I though the mask was to get the final output into wierd shapes for odd sized screens.
    but maybe I'm looking at it wrong.
