key map bug
  • videomasta
    key map bug
    by videomasta » Thu Jun 07, 2007 7:15 pm
    hello i am trying to connect a key to the luma on/off button of a specific independent from the selected layer. i use the mapping option "layerset + position".
    when the layer is selected everything works fine. i can press the linked button and
    the luma button switches from "on" to "off".
    but if i select an other layer a button press event only turns the luma key on
    and nothing happens on second key press !!!!
    with the master on/off switch, the key mapping works like expected !
    hope you fix this soon ......
    i am trying to use modul8 in a proffessional way since 2 month and
    i think its sill in a beta state ...
    very frustrating ....
    by boris » Tue Jul 17, 2007 1:36 am
    This bug is on my todo list and will fixed on the next release (very soon).
    by boris » Tue Jul 24, 2007 1:47 am
    This problem is now fixed, and the new release is now planned for the next week.
